rfloyd99's avatar
rfloyd99
Question re axle replacement
I have a 2016 Jay Feather RBM23 which I bought new. The tires were wearing unevenly (edges of tread wearing more, not uniform from one tire to the next). Of course, they are the cheap original equipment ones, and I had about 18,000 miles on them. I was very careful to keep them at the recommended 50 PSI, BTW, so I don't think the wear issues are related to low pressure.
When I took it in at the end of the warranty period (two yrs) for them to take care of a handful of minor issues, I asked the dealer if they thought I had an alignment problem, bad or improperly installed axles, etc. that could be causing this. Lippert made the axles, IIRC.
They took a lot of measurements, and said they'd get back to me. Months later they did, and wanted to come to my home an hour away to measure again. They did, and a couple of months later called and said the new axles had come in.
I have three questions:
1. Should I even have them change the axles? I know doing warranty work generates lots of money for the dealer, whether it's needed or not. They somehow got Jayco to replace the largest window and a small one under warranty when the only problem was that they were a little stiff to open/close. If there's nothing wrong with the axles replacing them could be worse, if they don't do it right.
2. Do new axles come with the bearings and brakes already attached, therefore giving me new ones along with the axles? (again, 18K miles, so new would be a plus)
3. If I do it, should I replace the yellow Equa-Flex (Lippert, I think) suspension part while they are at it? Again, consider the mileage. It seems the Equa-Flex is already an upgrade, but is wear a problem?
As always, thanks in advance!
Riley
