ilvtravln's avatar
ilvtravln
Explorer II
Oct 14, 2019
Replacing drum brakes ???
Need to replace brakes on my 5er, it has Lippert axles, drums are 12". Can I just replace the brake shoes or do I replace the entire backing plate, brakes, magnet all of it. Where do I go for parts?
Thanks
  • I replaced the brake assemblies and bearings last winter on my 2004 Keystone Cougar. If you have any mechanical ability it is fairly easy.
    Dexter 10' electric brake assemblies (4): $175
    Wheel bearings for 4 wheels: $54
    This time I used a company named Sturdy Built Trailer (online). I believe they were cheaper than etrailer for the same brand assemblies.
  • You also need to inspect the drums for wear on both the braking surface and the magnet surface. You can get parts at most anyplace that has trailer parts.
  • Sounds as though you've never done this before. Find a friend to help you through it as you'll also have to do the bearings.
  • Etrailer.com has everything you need. It's best and easiest to change the entire brake assembly.
  • The magnets wear down too and don't last through two sets of shoes.
    I agree with the PP, I'd replace the backing plates as an assembly.
    FWIW, I am very pleased with the automatic forward adjsuting units on my trailer.
  • If it were me and I was NOT able to upgrade to the electric/hydraulic disc system, I would take the 4 bolts off and replace the entire backing plate... Just make sure you get 2 left and 2 right
