Njmurvin
Aug 05, 2021Explorer II
From etrailer.com:
Question - "Do you need to place a support jack under trailer before you remove gearbox ? My tube on the gear side did not retract the same amount as the non gearbox side. I suspect gearbox may need replaced."
Expert Reply - "If you can level your trailer it is not necessary to add an additional support jack before removing your gearbox. The gearbox turns the screw that activates the jack, but it also has a fail safe that does not allow the jack to drop if the gearbox is removed. In the case you are not able to level your trailer, you will need an additional support jack."
All that said, I'm paranoid about being crushed. So, I'd hook it up to my truck for peace of mind.
About Fifth Wheel Group
