shadows4's avatar
Aug 05, 2021
Replacing front landing gear box and motor.
Hey guys, got a question. I am replacing my front landing gear box and motor. The 5er is in my driveway and is raised fairly high. I have a sloping drive and I can walk under the pin. I am 5'7". My question is can I remove the motor and gear box without lowering the trailer? Will it fall if I pull those two item? I would like to do this without hooking to the truck if possible. Thanks, John.
  • Tyler0215 wrote:
    What do you think is holding the fiver up? Of course it will fall. Hook up the truck and support and chock very well so the truck and trailer does't move.
    Not true.
  • These front jacks are a screw-type setup and will not fall if you pull the motor and gearbox. The motor and gearbox turn a threaded rod with runs in the matching threaded leg. That is what supports the trailer.
    JMO, but depending on how heavy your trailer is, you might consider going to a two motor system like the Bulldog legs. That's what I put on our Fuzion and it works so much better than a single motor setup. Plus a side benefit is being able to move the legs independently to allow for uneven ground.
  • From etrailer.com:
    Question - "Do you need to place a support jack under trailer before you remove gearbox ? My tube on the gear side did not retract the same amount as the non gearbox side. I suspect gearbox may need replaced."
    Expert Reply - "If you can level your trailer it is not necessary to add an additional support jack before removing your gearbox. The gearbox turns the screw that activates the jack, but it also has a fail safe that does not allow the jack to drop if the gearbox is removed. In the case you are not able to level your trailer, you will need an additional support jack."
    All that said, I'm paranoid about being crushed. So, I'd hook it up to my truck for peace of mind.
  • jdc1's avatar
    jdc1
    Explorer II
    On a slope, I would skip the jackstands.....use the truck.
  • You can possibly use a heavy duty jack stand to support trailer inlieu of truck. But you will need to support trailer somehow
  • What do you think is holding the fiver up? Of course it will fall. Hook up the truck and support and chock very well so the truck and trailer does't move.
