waltbennett
Dec 17, 2013Explorer
Not the same side - the same axle (the long tube with brakes on each end). Unless the older ones have a LOT of tread wear, there shouldn't be much difference in weight bearing between the two axles. What Goodyear is saying is to put the new tires on each end of the front axle and the older ones on the rear.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
