PawPaw_n_Gram
Dec 17, 2013Explorer
If Goodyear says this:
And the tire dealer says:
You either misunderstood what he said, or you need to find a new Goodyear dealer.
JIMNLIN wrote:
Goodyear says this in there RV website;
Mixing tire types and sizes.
When you mix tires of different constructions, sizes and depth of tread wear, it can affect handling and performance. Goodyear recommends using the same size and type of tire on the same axle – i.e., all radial ply or all bias ply, all the same size and all the same tread pattern – as well as maintaining your tires so that they all have approximately the same depth of wear.
wtmtnhiker wrote:
I was recently told by the Goodyear dealer that I should put the 2 new ones on the same side and have the two used ones on the same side.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
