Sea_Six's avatar
Sea_Six
Replacing Rubber EPDM roof - 2001 Jayco Designer
Finally decided to replace this 14 year old leaky roof.
Pulled off nearly all the EPDM (99%) - I'll get the rest off tomorrow.
I'm going to replace it with the same (EPDM) rubber roof. A local Camping World has the 35' by 9.5' replacement material, and a $235-ish installation kit with the adhesive and Dicor sealant.
Only two spots of the 11/32" BC Plugged plywood needed wood rot repair, which will be done tomorrow, IF I decide to keep the original wood... which leads me to my question:
The wood obviously is in pretty good shape, but it is still covered with the old adhesive.
I called Dicor company and their technical assistance person said their adhesive needs to be applied to fresh, untreated wood.
So... I can either replace all the wood, or I'm wondering if I can just put a layer of 1/8" luan over the top. If I do, will I run into any problems with the new EPDM roof being 1/8" higher than the original roof?
Two possible problem areas:
1) My model has the two fiberglass end caps. I don't know how to make the transition from the EPDM to the fiberglass end caps... does the original EPDM rubber material tuck under the fiberglass end cap? If so, I think I might not be able to tuck the new replacement EPDM rubber under the end cap if it also has 1/8" luan underneath.
Is there some other way to make this work? Maybe butt the EPDM/luan sandwich up against the fiberglass, screw the rubber/luan down with the piece of trim to hold it in place and just trust the Dicor self-leveling stuff to make the junction watertight?
2) Same question about the new EPDM connection to the sides... it looks like there is an aluminum "corner bead" that is stapled to the original plywood, that the old EPDM roof goes on top of. I'm thinking the Al "corner bead" can be removed, and reinstalled over the 1/8 luan, and the new EPDM roof material applied over that. My question is whether there will be any issues with the new EPDM material being 1/8" higher than it was before.
I've got two workers coming over tomorrow to help me finish this job... any comments would be welcome!
Thanks in advance!
  • Can you purchase the Eternabond tape locally or do you have to order it online?
  • Have you considered using Eternabond tape to cover the transitions from the EDPM to the fiberglass caps and along the sides? I have a 1995 Jayco Designer and have used the Eternabond tape in this fashion and it has held up very well for the past 3 years.
