fj12ryder
Aug 08, 2013Explorer III
Lantley wrote:
One needs to increase their capacity because the OEM tires are inadequate if RV is loaded to its full GVWR capacity
That's not entirely accurate. If the original ST tires were quality tires and would carry their rated capacity then a lot of time you would be just fine, especially if you're running 6,000 lb. axles. A 6,000 lb. axle with 2 3500-rated ST tires would be a decent combination, IF and that's a big IF, the tires were reliable, which they aren't.
In my case my triple axle toyhauler came with 6 E-rated ST tires, and a GVWR of 18,000 lbs. If the tires were good and would actually carry what they're rated for I would have been just fine.
But there are some out there that are borderline at best with their OEM tires/wheels.
About Fifth Wheel Group
