gpshemi
Aug 10, 2013Explorer
flyinguy68 wrote:
So you are saying that the Goodyear G614RST (an ST tire that is very much raved about on these forums) is not a quality ST tire.
You seem annoyed, so bashing comment aside, I'm just trying to educate since you've asked. There is no quality ST tire like an XPS Rib or Duravis R250 (or G614).
The "raved" Goodyear G614RST is actually an LT tire with a speed rating of 75mph, not 65mph like ST tires, and follows the standard inflation tables.
http://www.goodyear.com/cfmx/web/truck/line.cfm?prodline=160007
It would be a great choice of tire if, your rims can handle the pressure, you can find a size, and you can choke the cost.
My money is still on the Duravis. It's obviously an easier choice for me since I'm at 18k, but I'll point out what most people don't when looking at tire loading. Even if you load to 21k, in my mind you should be able to subract the weight of the pin on the truck (3500ish?) for actual trailer axle loads...even if the manufactures don't allow you to do such for the coach numbers. That's putting you around 17,500 on your triple when loaded to the limit.
Your best bet though is to stop asking everyone else and go weigh you rig. Then you'll know for sure whats on each axle.
Good luck with your choice. The GY's are a great tire too.
About Fifth Wheel Group
