TXiceman
Apr 03, 2020Explorer II
First try to gently tighten the 4 bolts from the top by removing the cover. If this does not work, you will need to pull the unit and replace the gasket. DO NOT try to use any caulk on the unit.
To install a new gasket, you will need to remove all 4 bolts, disconnect the wires and lift the unit off. Then install the gasket, sticky side to the bottom of unit. Re-position and tighten the bolts according to the manufacturers instructions.
Ken
Ken
About Fifth Wheel Group
