- LouLawrenceExplorer IIYep, likely just stripped. You can slip something between the screw and the shroud to act as a wedge and turn screw slowly. The good threads behind the stripped ones should grab and allow you to unscrew. Google remove stripped screw and you will find lots of other ideas.
- CA_TravelerExplorer IIIStripped? Remove with pliers and if not drill and/or use screw extractor.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
