dmorse68
Apr 05, 2020Explorer
pcm1959 wrote:
Those lag bolts that hold a/c unit on to the roof on many of the new RVs with no visible means of attachment on the inside are a huge source of possible water as they are outside the a/c seal and/or shroud. Be SURE they are properly sealed.
Many a/c units are leaking into the roof on these types of a/c units unknow to the owner since it is not likely to show up on the inside due to the insulation and ceiling panel particularly if a vinyl/padded ceiling.
The only way I discovered I had water intrusion was, I took the bedroom’s fantastic fan inner shroud trim piece off so that I could place a mouse trap up in the insulation cavity, and saw the roof plywood dark and wet.
About Fifth Wheel Group
