nayther
Dec 11, 2019Explorer
the 3 flashes says there is an error, you need to hold it down in off for a few seconds and it will flash the actual code, first set of flashes is the first digit, second set of flashes is the second digit. It repeats each set of flashes 3x I believe. then repeats so 3 flashes followed by 2 would be error 32. You need the codes, easily found on the web.
About Fifth Wheel Group
