ScottG wrote:
justme wrote:
2oldman wrote:
justme wrote:
That becomes 533 to 667 watts/hr.
Watt-hours?
That is how many watts are used in one hour
I don't think thats quite right.
You cannot use the momentary surge current of when the compressor starts to make the power usage argument over a long period of time. Modern fridges uses a fraction of that power when just running and they only run about 50% of the time.
This is why so many modern rv's can get away with using a resi fridge and don't require anything more than the standard charge line from the TV.
Just tested our own 2 y/o full size Samsung resi fridge in our home and it runs at 169 watts - easily sustained by a TV charge line.
Scott,
From the information that I have been able to obtain, modern inverter style residential reefers have, in general, about a 30% to 35% duty cycle. 20 years ago they had residential reefers down to 45% duty cycles.
Your 169 watts is actually quite realistic, (we use a Samsung in our residence). (169 watts would be about 31.5% duty cycle of 533 watts.)
As I mentioned in my first post, if not for the dimensional deconfliction that I needed, we would have gone with the Samsung in the RV. As it is, the F&P that we installed has been excellent. It is also (like Samsung) an inverter compressor system, and has something called ActiveSmart: "
"ActiveSmart™ Foodcare consists of a microprocessor, interior temperature sensors, independently controlled fans and multiple air vents.
The microprocessor controls how the refrigerator operates. The sensors continuously send information to the microprocessor, which analyses and adjusts the fan and compressor operations accordingly to deliver optimal results.
Cool air is distributed evenly and efficiently through multiple air vents, creating a consistent and stable temperature throughout your refrigerator and freezer. ActiveSmart™ Foodcare also has the ability to rapidly chill new items to a safe temperature and quickly freeze foods to retain moisture when defrosted."These reefers are nothing like what was being produced even 20 years ago.
