Thanks. That is encouraging. Still trying to remember when to switch inverter on and off. Guys did a good job at orientation, but lots of new stuff fast. He said remember green go-on for travel off when stopped or shore power! When not using fridge shut off breaker. Does that sound right?
Still learning the leveling system. To unhook put setting on extend and push “front” button after adjusting the feet where you want them. Extend until you can unhook and pull away. At that point push auto level and let it do its thing. Done. To hook up I think you push the extend/retract button and then push the “rear” button and that should raise both rear jacks? Then same process for the front. Does that sound right?
Thanks for your help. I’m sure I’ll be back at you come winterizing time.
Jim
