rodwood1
Mar 27, 2016Explorer
Reverse polarity
I have a 2 part question but the first is a statement,
I am a dummy,
I accidentally reversed the polarity on the battery today, when I went into the coach to open the circuit I heard immediately what took a few minutes to figure out 2 40 amp fuses fissile away,, after replacing them getting everything else back up and running" I think" the slide out still remains without power. I cant open it or close it its just DOA.. I have a 2007 Komfort M-27R does anyone know if there is a fuse, breaker, reset button or interrupter that I need to flip, push or change to get power back to the slide out and most importantly where it is??? I have looked in all the exposed locations? I hate to tear things apart blindly looking for something, as you can tell i do enough damage UN-intentionally.
Question 2 How strong are the Manual over rides? When I connected a 1/2 inch drive socked to bring the slide in,,IN, manually after a few loose turns I can see it begin to come in but all of the sudden it stops and gets tight,, I put reasonable torque on the ratchet enough for me to be concerned that I might break something, does it take a lot of force to manually bring it in// or will I break it if I really give it the torque???
I am a dummy,
