Bob___Mary's avatar
Bob___Mary
Rockwood Ultra Lite
Hello all - been awhile since last post.
Mostly out of curiosity but would appreciate any feed back on Rockwood Ultra Lite in general and model 8289WS in particular.
Wondering where it fits on the Fiver "food chain"?
Thanks - any input appreciated.
Bob
  • Don't know if the quality has changed in the last few years but my parents have a 2012 that has been nothing but a nightmare. Major quality issues from the start requiring months and months of down time for repair including a trip back to the factory.
    The entire roof was replaced after it rotted from leaks in the first year. It leaked around the AC and shower skylight plus the luan panels used to make the roof were sharp around the edges and poked holes through the roof membrane. The axles and tires were replaced as they were undersized from the factory and bent. Front cap was replaced twice from warping. Water heater was replaced. Skirting around pin had stress cracks. Radio never worked and the wiring for the antenna was laid across the slide roof under the rubber membrane so that the weather stripping rubbed a hole through it. The slides were so crooked that you could see daylight and the floor got wet any time it rained. The uneven slide also wore a hole in the vinyl flooring.
    The list is much longer but I can't remember it all. Thank god they had an extended warranty but it wasn't worth the stress and hassle. It took a lawsuit to get it sorted to a point that the TT was useable. If you consider the Rockwood, get a thorough inspection, an extended warranty and a competent service manager.
  • I liked that one a lot, but went with the similar Grand Design 303RLS.
  • I researched this brand/line of trailers pretty extensively prior to buying my Keystone Hideout. Like my Hideout, the Rockwood is a pretty mid/low end product. To me a lot depends on how often I plan to use it. I'm still working so it's just a few weekends a year and a few weeks in the summer. For that, these lower end RVs are great and I feel I'd be throwing money away in depreciation on a more expensive unit. If/when I have more time to be out camping there's no way I'd expect one of these "weekend warrior" units to hold up.
  • No experience with Rockwood so I can't comment on the quality....but
    Our friends have a very similar floor plan trailer. What they don't like about it is that when the slides are in, they can't access the frig or pantry. The slides pretty much block the back half of the trailer ..makes it harder for a quick on the road stop for lunch or such.
    Don't know if that matters to you?? Otherwise it looks like a great unit. You will really like the rear lounge plan. Good luck with you search and choice.
