Dayle1
Aug 21, 2013Explorer II
Assuming that the walk-thru door is a standard 80 inch door, then it looks like the larger door opening is about 13 ft tall. So does that mean the clearance is less than the door opening due to the roll-up door hanging too low? If so, I agree that a sectional door can fix the clearance issue by allowing full use of the frame opening. How wide is the door, maybe 14ft? My sectional door is 13-1/2 ft tall and 14 ft wide and I wouldn't want anything less. It is a commercial insulated steel door and weighs about 400 lbs. I also recommend the Chamberlin Liftmaster door opener, it mounts on the torsion bar shaft, self programs stop points and works great. Much better than the usual chain drive system with a very long chain.
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 13, 2026
