Dave_H_M
Aug 22, 2013Explorer II
schlep1967 wrote:
Two possibilities. Low profile a/c unit. Might not get you all that you need. Concrete saw. Cut out the paths of the tires down to the stone base. Maybe lower. Install some drains then repour concrete at a lower level. Sloping them out the door so water does not run in. Just some thoughts.
That is the way i went but just put road pack in the slots cut in the floor. Cut out wood panels to drop in the slots to keep the varmits out. I only had to cut the floor back far enough until the AC cleared the header, then sloped the cuts up so the fifth wheel backed up on the concrete floor.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
