Curlida's avatar
Curlida
Roof Maintenance
Hey all,
I know this should probably go under tech. Issues so if moderator decides to move it that's fine. But since it pertains to my 2016 Montana 3711FL I thought I would put it here. First is there a way to tell if your roof is EPDM or rubber? The dealer told me EPDM but they are not that reliable. Also are the cleaners and UV Protectants that camping world sells.worth the money or is there something else better or recommended.
  • Curlida wrote:
    Thanks all for the info. Harold 1946 where do you get the aerospace 303 and is it pricey ?
    Many RV dealers carry it, around $16./ quart. Some Walmarts also have it. I purchase it online for $50/ gallon directly from 303 products. It is also available on Amazon.
  • Thanks all for the info. Harold 1946 where do you get the aerospace 303 and is it pricey ?
  • I used to coat my class A's roof with the camping world product, it was supposed to, seal the roof, provide RV protection, and by being reflective reduce heat transfer. I never had any problems, costed three times in nine years. That being said, I did nothing to the roof of my C, and also never had any problems.
  • Your wise to investigate about your roof. They're not cheap to replace and a lot of damage can result if not maintained. Link provided is to get you started. On page 10 (I think) has a flow chart so you can figure out what type of roof material you have. To look under neath your roof material, remove the plastic garnish ring under a vent and take a look. Also there are some videos on line.
    http://www.dicorproducts.com/resources/guide/RudysRoofbook_16.pdf
  • I don't do anything with my roof. Every time you wash it you remove part of the wear layer. It gets a little chalky so what? My park trailer sat out for 10 years in the weather. Never did anything but caulk it. Nobody that I care about sees my roof so I just leave it alone.
    B.O.
  • Some use Blue Dawn Dish Washing Liquid. Agree you can spend all amounts of Money on different produces, but in the end all it needs is a decent cleaning several times a year.
  • Follow the roof manufacturers instructions. Like others, I wash the roof with a mild detergent like Spic N Span, and check caulking. If it makes you feel better, go ahead and spend the money on the protective coatings.
    There will be spots from tree sap and bird droppings which will not kill the roof. I do not try to get my roof snowy white since the only time I see it is when I got up top 3 or 4 times a year.
    Ken
  • Your roof is likely EPDM, which is commonly called a rubber roof.
    Unless you have indoor storage, it will be hard to keep your roof looking like new. I wash my roof a couple times a year with car wash soap, and car wash brush. This is a good time to check for any areas that may have caulk issues, cracked or damaged vents, etc.
    Jerry
  • The two most commonly used roofing materials are EPDM and TPO. They are both maintained in the same manner. Murphys Oil Soap is what I prefer for cleaning but there are many other products that work just fine. Just be sure not to use anything with citric acid or petroleum distillates.
    I use Aerospace 303 Protectant, which is SPF 40, on everything from the AC shrouds to the tires. except the glass.
