I have a 1995 29ft Carriage Lite 5th wheel. It still has original rubber roof. It does not leak. What should I replace the roof with? Can I put the liquid bed liner on the roof?
Is it in bad shape? If not, just keep it sealed up. Options - which are going to run $7-$9k retail are TPO or EPDM material - and may require new wood on top.
You can also do RVarmor - which is reported to cost substantially less: http://rv-armor.com/index.html
