4x4FF's avatar
4x4FF
Rotate landing gear leg inserts
Im getting ready to put som JT Strongarms on my 5er but on my front landing gear I noticed that the legs seem to be 90 degrees off from what I normally see. In other words, the pull pin to adjust the leg inserts is actually in the rear so looking at the front of the trailer you can see all the adjusting holes on the landing legs.
I need to pull the inserts out and rotate them 90 degrees. The holes and everything else is in place just not sure how to go about getting the thing high enough to drop the legs out if they even will drop out.
Any ideas??
Thanks,
Steve
