4x4FF's avatar
4x4FF
Rotate landing gear leg inserts
Im getting ready to put som JT Strongarms on my 5er but on my front landing gear I noticed that the legs seem to be 90 degrees off from what I normally see. In other words, the pull pin to adjust the leg inserts is actually in the rear so looking at the front of the trailer you can see all the adjusting holes on the landing legs.
I need to pull the inserts out and rotate them 90 degrees. The holes and everything else is in place just not sure how to go about getting the thing high enough to drop the legs out if they even will drop out.
Any ideas??
Thanks,
Steve
  • 4X4FF;
    Our new 5th came with factory installed JT Strongarms. Unless the aftermarket kit is different from the OEM kit I'd say your landing gear legs are correctly oriented for the Strongarms.
    The lower arms attach to the back of the legs with the nut on the front of the leg. You'll have to enlarge the lowest hole to 1/2" for the through bolt if it's not that size already.
    You may have to move your 5" fence post sewer holder as the arms may hit it when you have the gear retracted. Hard to say from your pictures.
    Ours has the Snap-pins facing forward by the way.
  • sdfiver wrote:
    4X4FF;
    It would be easy to swap the snap-pins to the front. That might be my simplest option. I already planned on moving the sewer hose holder back quite a bit.
    Steve
  • NWKomfort350 wrote:
    laknox wrote:
    4x4FF wrote:
    Here is a pic of how mine currently is:
    I'm no expert, but I can't say I've =ever= seen a FW without the pins facing outward.
    Lyle
    The pins in the landing gear legs on my 5er are side to side.
    I've always moved mine to the back, I've found they don't collect nearly as much road grime on the handle.
  • mrw8i wrote:
    There is an online video about installing Strong Arms. The holes are front to back.
    Strong Arms Install Video
    I'll be danged!!!! I've even watched that video before and didn't notice it. All I have to do is swap my pull pins from the front to the rear.
    Thanks!!!!!!! Great find!!!
    Steve
  • Interesting. I have factory installed and the holes are in the side. On our last unit, I installed them and the part that attaches to the inner leg, attached to the bottom pin through the pin that attaches the foot to the inner leg.
