partsman01ExplorerJul 14, 2014Rubber plugs bulging out on easy lubeDoes it mean anything when the rubber plug on a easy lube bulges out? The end looks like a nipple cause it is sticking out, hot day towing but hub did not seem too warm to touch, had to use brakes a ...Show More
fj12ryderExplorer IIIJul 14, 2014Most likely is grease working its way out. I'd pull the caps and clean out the excess grease. Did you just have them lubed?
Related Content7 pin plug amperage rating?Bulge in exterior fiberglass...Liquid rubberRubber Roof ReplacementTire bulge
