aemedic's avatar
aemedic
Rubber roof pulled out from side...
I found this today:
I have no idea what happened, it does not appear damaged, it's just pulled out...
Has anyone one seen this or know what it takes to fix it?
  • If you can turn a screwdriver, pull back the center cover/filler material, back the gutter screws out a bit, pry the gutter back a bit and push the roof rubber down, retighten and open a beer.
    If its under warranty ignore above and drop off. Either way, no big deal and is a quick fix.
  • Thanks everyone! I am making contact with Northwood, to see what they think of the issue. The TH is an 08 so I don't think I should be having this issue and they may be able to set me straight on what materials to use during the repair.
  • Give the folks at Northwood a call or drop them an email with that photo and see what they advice for you to do would be my suggestion.
    For service on your trailer:
    Email: service@northwoodmail.com
    Phone: 541.962.6274
    7am-4pm Mon-Fri Pacific Time
  • Just my opinion. Probably and hopefully it just came out from bad job of installing it in the first place. You won't know full story until you take off the vinyl insert and loosen a few screws and can see what is really going on.
  • That's terrible!
    I suspect that the adhesive has given out and it is probably billowing on top as you go down the road. That's the only way I can see it being pulled away from the edge like that.
    Scott
