fivecodys's avatar
fivecodys
Rubber Seals On Cargo Hatch Failing
The rubber seals on all three of my cargo hatches are pulling away and look as though they have shrunk.
They cut across the corners of the openeing instead of following the contour.
Any suggestions on replacement material and where I might lay my hands on some?
Many thanks-
Bill
  • So, which seal did you find works best for the baggage compartments? I need to replace it on 3 exterior doors. And looking at what's there isn't going to help me since they're broken off and flattened all around. Thanks!
  • Any good RV dealer, Lowe's, Home depot or any good hardware store. Be careful not to stretch when installing as that is what causes your problem. :)
