Diesel_Camper's avatar
Feb 01, 2016
Run AC from inverter in truck?
Just wondering if a 160 amp alternator can handle running an AC unit through an inverter? Also would a modified sine wave run it or would it need to be pure sine wave?
I'm not sure if the AC is a 13.5 or 15k btu, I know that will make a difference.
Let's assume that a generator is not an option and the truck will be running.
  • The engine would need to running at higher RPM to the rated speed to output 160 amps. You would need to connect something near 2/0 cable for the positive and negative of the 12 volts between the alternator and the inverter.
    I would not even attempt it!
