2btowed
Nov 11, 2015Explorer
Answer to question,is yes you can run jenny while towing,but as most have said ,do'nt do it just to run the outside frig.If you have at least 2 good batts you could see amp draw on little frig and get small inverter to run it .Truck will help charge batts as you drive, so it should make it.It would work this way when boondocking also.You could also get 12v/120v unit and replace the little frig .That is what I did and it is a great improvement.A little pricey but 125 cans of 30 degree is nice...
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 15, 2026
