deltabravo
Nov 12, 2015Nomad
turbojimmy wrote:
Sounds like the outdoor kitchen has a dorm-style fridge which is presumably electric only. I would keep everything in the propane/electric fridge if possible and run that on propane. Transfer what you need outside when you're hooked up to shore power. The generator will be using a lot of fuel to run that little fridge.
And, like others have said, there's no reason you can't run the generator while you're moving but the question is whether it's efficient to do so. I only run mine for the A/C, not the fridge. Although if I happen to be running the genny for the A/C I'll switch the fridge to electric.
Ditto on the above.
Only time I'd likely use the small outside fridge is when connected to shorepower, or if I had a huge battery bank, inverter and large solar array.
Running the gen just to power that small outside fridge is an inefficient use of propane.
I'd have no problems running the gen while going down the road.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 15, 2026
