Old-Biscuit
Sep 09, 2015Explorer III
Colo Native wrote:
I am going to use a portable generator. How did use guys run the electrical for the plug up front?
Originally I used a 'auto transfer switch'
Both receptacles (power sources) feed into switch and then output goes to RV Main AC Panel
I used a Marinco 50A Twist lock receptacle (just like my OEM)
20'/each of #6 wire in Black (L1 Hot) Red (L2 Hot) White (Neutral) and Green (Ground)
Installed receptacle on left front wall under overhang and ran wires (bundled) to transfer switch on wall of basement compartment.
Wired them to one input/OEM to other imput and main wires to output.
Changed all that later to 'manual swtich' due to transfer switch issues (faulty/failures.....factory/mfg. issues). That was 7 yrs. ago.
Better transfer switches available.
BUT my 'manual' switch works/dang near fool proof and repair if EVER needed is cheaper than transfer switches.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
