rhagfo
Sep 21, 2017Explorer III
DE47 wrote:
I have a 4-seasons 5th wheel that I recently put a cover on for the summer. If I leave that cover on can I still run the furnace over the winter to keep the underbelly warm?
What is your goal? Do you want to avoid winterizing the water system, or keep out the damp?
I assume you have power to the unit while in storage, otherwise you Gould kill the battery in short order.
If you have at least a 30 amp outlet available I would suggest installing a Cheap Heat system, and run it as it is all electric, dry heat and no heat out the exterior vents! Ice heated air through the heating ducts.
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
