BobWanderer
Jul 28, 2013Explorer
Winterwolf227 wrote:
I want to be able ot turn on my Tail/Running lights while parked and NOT attached to my truck. Can I run a pigtail with a wire from Port 3 to port 4> Will that work? I have seen it done at RV shows and wondering if it will work the same way?
I used a flasher and a circuit breaker and a plastic electrical box to make the brake lights flash. But it would be just as easy to make the running lights flash with the setup.
I don't have it here since its in storage right now or I would show some pics.
You get the power from #4 and then to the breaker and then to the flasher, then to #5 & #6 in my setup.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
