ChuckSteed
Mar 16, 2017Explorer
If you are talking about the hydraulic type slide outs they each have two gear packs underneath that do require cleaning and proper lubrication to promote long life and good working order
Use PB penetrant to clean off the rust that builds up on the gear pack teeth and bar.. Clean as best as possible, dry off the penetrant and then use PB graphite dry lubricant spray, usually fray in color to,libricate the teeth and rack assemblies...WD 40 is really not the right stuff to use for these as it gathers dirt and dust and has no staying power like the dry graphite spray does..
There is also a procedure on Lipperts web site that shows you how to service the gear packs if they develope a squeal or your slides are sluggish...
I do both of these at the beginning of each season
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
