rhagfo wrote:
I agree that he is high hitched, as at 19.33 there is a slight space between the two Teflon surfaces.
Then at 19:44 you can see that space again, and it doesn't look like the sliding bar goes gar enough to the right.
Do this look at 19:33 , and see the handle position . Now go back to the video ,and start at around 3:35 , and see where they are messing with that handle , and you will see it in the CLOSED position, and then tell me that handle was closed in 19:33, it was not .
IMO if there is a gap ,its not enough to call it high hitching, when I take some of the weight off of my hitch ,yes I can see it start to separate,and a bit of gap but its not high hitched its still hooked up. Then I pull the handle ,and pull out.
If you look at that video there never was a shot of that hitch AFTER he had let the weight down. All those shots were with the landing gear down , and there could of been just a slight gap until he did let the weight down on the truck .
I won't go back thru it again what I saw first hand. After looking at that hitch that fixed teflon plate is all that is needed. He had the other on the pin box, like most do. Too much there too allow the handle to close completely bound up the handle ,the rest is history. If that lube plate had not been on that pin box, IMO that handle closes ,and he drives off.
