elishaman's avatar
elishaman
rv extension cord
I am planning a cross country rv trip and need to get a power extension cord. What do you feel is the maximum length I will need? Trying to not buy more than needed as storage is a premium on our 5th wheel.
  • When we got our 1st 5er (30amp), bought a 25' or so 30 amp ext cord. Now that we have a 50 amp 5er, I needed to use the ext cord, but in doing so, only used what we needed to because of lack of avail power supply thru cord. In other words, only 1 A/C unit out of 2 or and water heater. No probs. If we had to, could have switched wh over to gas, and have lil more power to use otherwise. But overall, just have to live within the means of of the 30 amp cord. If a 50 amp ext cord is avail, might be a heavy thing unless a sow cord can be found (just learned of this cord last week).
  • Agree with Wiscamper. But at the same time there is always the chance of you feeling the need to say Well Darn... And you need just two more feet... Happy travels.
  • I would recommend a 25' extension cord. Combine that with the power cord from your 5th wheel should be enough to reach the power pedestal. Keep in mind if your 5th wheel is 50AMP the extension cord like your power cord will be heavy.
