spoon059 wrote:
I'd be a LOT more interested if they had a product that was about 8" wide right where the rubber roof meets the front, side and back walls.  That is the weak spot in the traditional RV roof.  The other 95% of the roof is perfectly fine.
It would be similar to Eternabond tape application around the seams, but ideally look a little more professional.
 Seams are always an issue on any roof.
But claiming the standard roof is fine vs. Flex Armor is misleading.
Sort of like claiming standard drum magnetic brakes are the same as disc brakes.
Both Flex Armor and disc brakes are a significant improvement vs. the standard OEM counterpart.
