stpettasExplorerDec 27, 2015Rv heaterOur heater goes off. Then when we turn it off and then back on it will work and then go off
ksg5000Explorer IIDec 28, 2015Are you plugged into shore power? If not then status of battery becomes an issue - heater fan takes a lot of electric juice and if your battery isn't up to snuff then the fan slows down and the sail switch which allows the furnace to run will close.
Related ContentAtwood water heater problemRV Water heaterWater Heater Replacement RecommendationsReplace insulation inside heater column.Suburban SW12DEL Water Heater On/OFF switch melts???
