stpettasExplorerDec 27, 2015Rv heaterOur heater goes off. Then when we turn it off and then back on it will work and then go off
ReVokerExplorerDec 28, 2015We had a random on/off problem similar to what you describe. Ours was caused by a loose wire in the thermostat. When the trailer moved slightly the power would go off.
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsReplace insulation inside heater column.RV Water heaterWater Heater Leak on start up.
