Scott_85's avatar
Scott_85
Rv trim
The more time I spend In my camper the more pices of trim I see missing, is there a place I can get rplacement trim?
  • This week is Coachmen's 50th Anniversary Rally. Hopefully you can benefit from some of the good will they are supposed to be spreading around. Wish we could have attended but just didn't workout for us. I do know of at least 3 couples that are attending. Anyway good luck to you Scott. You shouldn't have to do this it should be your dealer doing it.
  • Sturgeon-Phish wrote:
    Take a piece to Lowes, Home Depot or where ever and see what comes close, finish and attach with glue.
    Jim
    I did that after work and no dice. I'm going to call the manufacture tomorrow and if they will not help I'm going to try a custom cabinet place to see if they can't make trim to match.
  • Take a piece to Lowes, Home Depot or where ever and see what comes close, finish and attach with glue.
    Jim
  • Sorry to hear that. Bad dealers are a problem in all industry. Best of luck in finding your trim.
  • glazier wrote:
    Scott_85 wrote:
    There are pieces that are no where to be found.
    That's a whole new situation. I would start with your dealer, they probably keep some trim. Install the new pieces with some glue, and brads it should be a permanent fix.
    Yeah that ain't going to happen, I would have better luck getting blood from a turnip.
  • Scott,
    When my new Cedar Creek was missing a 2" piece of external trim, I called CC and they sent me a piece as big as I wanted...which was 6", at no charge. I suggest you call your manufacturer as ask the same as I did.
    The best thing to do is, re-install the pieces with brad nails and adhesive.
