Duck
May 30, 2014Explorer
goducks10 wrote:
FWIW http://www.rvbusiness.com/2014/05/rv-warranty-forever-dealers-seeing-results/
For Travel Trailers;
On an annual basis, you must perform the following maintenance
1. Inspect roof and seal where necessary
2. Axle and hub lube
3. Furnace - annually inspect and clean blower and combustion chamber. Control compartment,
remove any dust, lint, and obstructions. Test for gas line leaks.
4. Hot water heater - flush holding tank, manually operate pressure temperature relief valve, and
clean burner tube as outlined by the manufacturer.
All required maintenance must be performed by a professional repair center.
With the cost of labor today that would add up to a nice size bill. The average non mechanical could perform most of those.
Don
About Fifth Wheel Group
