b_pilot's avatar
b_pilot
RVing in cold weather
We have a 2010 Bighorn 5th wheel. Thinking of going to Breckenridge, CO around the middle of March for spring break. Temps at that time should range from low 20s at night to upper 40s in daytime. Would probably not go if temps forecast to be lower than that. Will be staying in Tiger Run which is open all year with heated water hookups. Has anyone on this board had any experience with that type of cold weather camping in a 5th wheel? Our RV has a heated underbelly and I would insulate water line to camper. Wouldn't hookup sewer dump until necessary and then disconnect after dumping. Any input would be appreciated as we are still in the thinking process.
  • Overnight to 5F along the Alaska Highway in March
    http://yukonsights.ca/20130329_Rancheria-Liard.html
    -40 in a motorhome, also along the Alaska Highway
    http://yukonsights.ca/20011215_AlaskaHwy.html (link fixed on edit)
    Check the bottom of the second link for my lessons learned with the motorhome.
    With the fifth wheel, the fresh water tank was exposed so I had water in jugs inside. The fifth wheel also has a programmable thermostat which means we can keep the heat turned down to 41F at night and have it come on in the morning to warm things up before we get out of bed.
