- JAC1982ExplorerOur old hauler was a 9' garage and we fit our 900S (106" long) in there with maybe a quarter inch to spare. When buying the RZR we took the hauler down to the RZR dealer to make sure it would fit since measurements on spec sheets could be off. We actually didn't like hauling it that way though, felt like a larger bump in the road could cause the RZR to move a bit and damage the front garage wall.
So, I guess the answer is, yes you could do it as long as the measurements work, but I wouldn't recommend such a tight squeeze. And, actually try to park the RZR inside before committing.
ETA: just realized this was an old thread. Leaving my answer up in case someone else cares to read it :) - TxsurferExplorerwhat trailer did you end up with?
- Teebone56Explorer
Well to answer my own question 2017 XPT...........I M IN??
Mod Edit: Fixed image tags - N-TroubleExplorerRhino... That's funny, and I own one
My cousin just bought a Maverick and that thing is a beast on the bottom end compared to RZR1000. Both great/capable machines out of the box. - Teebone56Explorer
Strabo wrote:
Buy a Rhino, they fit and are faster, bigger, better...More
Done the Rhino to the max......... Rotax, 850 Rotax, turbo ROTAX....magnum off road long travel.........:)
- souraiderExplorer
- StraboExplorerBuy a Rhino, they fit and are faster, bigger, better...More
- magicmantxExplorerWe have a 310 Fuzion which has a 10' garage. It measures exactly 120" door to wall. My 14 xp1k just fits. I built custom front and rear bumpers which are close to the body and don't extend out further than the 30" rocktanes. You have to make sure and load exactly straight but it fits just fine. i would rather it just fit and have the extra room in the living area.
- johntankExplorer
Teebone56 wrote:
Anyone hauling an RZR 1000 in a 10 foot garage.
People tend to get pretty creative in making toys fit......
Going by the specs on the Polaris web site the only RZR 1000 that would fit in a 10' garage would be the 1000 EPS at 106" long, all others are 119" long. I can't see how one could fit any of the others in a 10' garage without some type of damage to either machine or trailer just not enough clearance. JMHO - N-TroubleExplorerNot every 10ft garage is exactly 10ft. Best thing to do is get out a tape measure and compare your garage to the RZR length spec of 120". If your short you may have to remove front bumper.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
