melybball's avatar
melybball
Sabre Cobalt 30RLT 5th Wheels
Hello,
I am interested in a new 2018 Forest River Sabre Cobalt 30RLT - 5th Wheeler. I have a 2017 Dodge RAM 1500 HEMI V8 4X4, has any towed a 5th wheeler with this truck or does anyone know if this truck can tow the Sabre? the Sabre dry weight is 10,104lbs
Thank you
Ana
  • MFL wrote:
    Welcome to the forum Ana!
    I doubt many would use that truck to tow the size/weight FW you are talking about. With a dry wt of 10K+, the loaded weight could easily be 12K. This could put 2,400+ lbs right over your rear axle, and is not including the hitch wt, or cargo/passengers in the truck. Your truck's entire payload will be around 1,500 lbs.
    Jerry
    I agree with Jerry. Running the dry weight numbers through TowingPlanner.com, you're looking at a wet loaded pin weight in the ballpark of just shy of 2,600 lbs.
  • ACZL wrote:
    goducks10 wrote:
    Thats a 3/4 to 1 ton 5th wheel. No 1/2 ton can tow it.
    Aw c'mon man, the RV salesman said my truck could tow it!
    LOL, I'm not sure a salesman would even stoop that low.
  • To better explain your truck's capability, you need to look at all the ratings, GVWR, GCVWR, RAWR, and payload sticker. All but the GCVWR will be inside the driver's door opening.
    Jerry
  • Sorry but that's just not enough truck by quite a wide margin.
  • Welcome to the forum Ana!
    Jerry
