thedoghouse
Mar 15, 2016Explorer
Sailun 637
Just for info I ordered set SAILUN 637 G load tires for friend and this size is almost identical in diameter size of the GOODYEAR 614. 30.7 inches so good option to consider
Lantley wrote:4bearhug wrote:
Not bashing these tires cause I have no personal experience with them, but wondering why not just go with LT tires which are readily available and tested to a higher standard than ST tires? Cost is approximately the same and wear should be better.
My older Sailuns are labeled as LT tires and stamped for trailer use only.
The newer Sailuns are now labeled as ST tires. My understanding is that there have been new tariffs put in place on LT tires that Sailun avoids by labeling the tires as ST. The ratings have not changed only the designation.
4bearhug wrote:I could have put "E" rated LT tires on my toyhauler and been within capacity since I have weighed all wheels and know the individual weights. However I decided to replace the tires with tires rated to the axle capacity of my toyhauler, which has 7,000 lb. axles. In my case it was a simple CYA decision.
Brewurown wrote:
75 mph
