NC_Hauler
Jul 07, 2016Explorer
JIMNLIN wrote:bpounds wrote:On theProwl wrote:
I confirmed with local tire dealer today. He says that it is no problem running 110psi in that wheel with those tires. He states that overloading the wheel weight rating is what will cause wheel failure. I've dealt with him for years and he knows his stuff. I'm not saying he's right or wrong, but i do value his opinion and feel it trustworthy.
I also know between this forum and the Jayco forum that several are running the same setup on the same wheels.
This is the correct answer. Wheels are designed for a load limit, not a pressure limit.
But all the "experts" around here won't agree.
Even real experts like a wheel manufacturer/axle manufacturer/tire manufactuers/rvtiresafety.com and many other sources disagree with that statement.
This from Dexstar wheel/Dexter axle
WHEELS & TIRES - What tires can I use on these wheels?
Wheels and tires must be matched. The wheel will have a label stating its rim diameter, width and contour. The tire selected must be approved by the Tire and Rim Association for use on that particular size wheel. The tire capacity selected should not exceed the capacity rating of the wheel. The tire inflation pressure must not exceed the pressure rating of the wheel. WARNING - The use of tires that are not approved for use on a wheel could result in explosive separation of the tire and wheel and could cause a serious accident.
Load a 16" 3100-3200 lb rated wheel to 3200 lbs and then add 110 psi can and has resulted in a split bead or a cracked valley. BTDT more than once..... and saw lots of examples of using pressures above the wheels max psi ability when I was on the road.
Lots of 16" trailer and truck wheels out here with 3200-3600 lb load rating and a 80 psi max rating.
Don't over pressure a tire or wheel. Sooner or later it will bite you in the butz.
Agree..That's what I was trying to say..
Thx,
Jim
About Fifth Wheel Group
