For those of you who say that the original poster could run the G614's with 80 PSI, I expect that Goodyear's weight/vs pressure tables might bear that out but I prefer to carry higher PSI in my tires on a trailer with similar weights. I always run 105 PSI and can see no unusual wear after 3 years and 30,000 miles.
I know that under-inflation is one of the biggest problems with trailer tires but I've never seen any indication that over-inflation (as long as it is within the wheel/tire's capability) is an issue. Sure, the ride might be harsher but I don't see any evidence of that in my trailer's contents and doubt that 80 PSI vs 105 PSI would be noticeable at all in the trailer's ride quality.
I will err on the side of carrying too much PSI rather than too little....
