GoPackGo wrote:
You'll need to pull the wheel off first.
The wheel maximum PSI should be stamped on the inside of one of the spokes, along with max weight/wheel. Will also have the rim width. It'll probably be pretty dirty so might need a flashlight to easily read the numbers.
I checked my rim this morning and it is a 110 psi wheel, so at least I do not need to buy new ones.
I should have been more clear. The info was stamped on the BACK side of my wheel, but it was actually on one of the spokes. I think I'm now in alignment with the poster above.
