Cummins12V98
Feb 03, 2015Explorer III
I changed from GY Wrangler US Made "E" to GY "G" the rims were 80psi rated. I ran the tires at 85 psi per GY Tech support. My load had the "E" tires maxed out required 80 psi for the load. GY says when up sizing use the charts based on load then add 5psi. The GY G's wore perfectly at that load and 85psi with many thousands of miles. Not worth sweating the extra 5psi on the rims!
Anyone going from E to G's and the load only requires 80psi and you run 110 you are going to have un unsafe, rough ride. Yes unsafe because the tread contact patch for braking will be reduced by over inflating the tires. Just ask GY.
LT235/85R16 "G"
Load Pressure
3170 85
3300 90
3415 95
3550 100
3675 105
3750 110
LT235/85R16 "G"
Load Pressure
3170 85
3300 90
3415 95
3550 100
3675 105
3750 110
About Fifth Wheel Group
