NC_Hauler
Feb 03, 2015Explorer
Me Again wrote:
It helps when a person gives us all the required info. This thread just shows how crazy people get, making recommendations without doing any research!!!!
http://www.tripleerv.com/downloads/pdf/2009/topazbrochure.pdf
OP has a 2009 Triple E F254SSXL with a 9390 GVWR. I came OEM with ST235/80R16D rated to 3000 pounds. Ribs or R250's will be just fine!!!!! Will only need 55-60 pounds for so inflation! I have more weight on my axles than his GVWR and run 71 punds inflation.
OP could do fine on 215/85R16E that would match the diameter of his OEM ST. This size is rated to 2680 pound each.
Chris
That was my consensus also Chris, I had E rated tires on a Coachmen 5er with a GVW of 14,000#, and E's were enough...I looked at the specs, same as you and couldn't justify a G rated tire..but if they wanted to go with an E, what you mentioned in the line of an E rated tire is MORE than enough tire for no more than the GVW of their 5er is.
About Fifth Wheel Group
