Artum_Snowbird's avatar
Feb 02, 2015
Sailun tires versus Michelin
I have to make a choice here, and both seem like huge overkill, but I am looking for opinions.
Sailun tires are S637 235/85/16 They carry a lot more, 3750 at 110 psi compared to Michelin LT XPS Rib 235/85/16 that carry 3042 at 80 psi
Sailun is 11/32 depth, Michelin is 15/32
Sailun is 61 pounds per tire, Michelin is 55 pounds per tire.
I would be running them at about 50% capacity for the Sailuns and about 60% for the Michelins.
Sailuns are about an inch bigger than the original 235/80/16. Michelins are about another half inch tall. I think the height would be an advantage, I could use another inch in hitch height.
Both super tough tires, but the Goodyear Marathons build in 2008 have to go before we go too much further and they cause a huge problem.
And both about the same price too.
What do you think?
  • You might also look at Bridgestone Duravis R250's. Cheaper than XPS Ribs and just as good. Heavier than the Ribs. Steel ply carcass like Rib and Sailun. If you have 6k or lighter axles,there is no reason to go to LRG tires. Chris
  • Look at the load ratings and speed ratings. Also the ply
    Also go to TireRack.com for the reviews and all things tire research.
    Don't cheap out!
